Time Before: 0.00445 seconds
Time After: 0.00621 seconds
Time Taken: 0.00176 seconds
Time Before: 0.00630 seconds
Time After: 0.00686 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00707 seconds
Time After: 0.00718 seconds
Time Before: 0.00788 seconds
Time After: 0.01036 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00723 seconds
Time After: 0.01374 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01749 seconds
Time After: 0.01790 seconds
Time Before: 0.02045 seconds
Time After: 0.02170 seconds
Time Before: 0.01667 seconds
Time After: 0.02190 seconds
Time Taken: 0.00524 seconds
Time Before: 0.03107 seconds
Time After: 0.03127 seconds
Time Before: 0.03554 seconds
Time After: 0.03682 seconds
End call of global.php: 0.038432121276855
Time Before: 0.04035 seconds
Time After: 0.04053 seconds
Time Before: 0.04302 seconds
Time After: 0.04449 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123842'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.05775 seconds
Time After: 0.05799 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.056852102279663 seconds with 9 queries, spending 0.0081689357757568 doing MySQL queries and 0.048683166503906 doing PHP things.
