Time Before: 0.00227 seconds
Time After: 0.00306 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00317 seconds
Time After: 0.00366 seconds
Time Before: 0.00395 seconds
Time After: 0.00409 seconds
Time Before: 0.00497 seconds
Time After: 0.01073 seconds
Time Taken: 0.00576 seconds
Time Before: 0.00418 seconds
Time After: 0.01536 seconds
Time Taken: 0.01118 seconds
Time Before: 0.01727 seconds
Time After: 0.01764 seconds
Time Before: 0.02019 seconds
Time After: 0.02133 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01672 seconds
Time After: 0.02150 seconds
Time Taken: 0.00478 seconds
Memory After: 2,261.703 KB
Time Before: 0.02725 seconds
Time After: 0.02739 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02951 seconds
Time After: 0.03077 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.032734155654907
Time Before: 0.03425 seconds
Time After: 0.03439 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03638 seconds
Time After: 0.03785 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=123863'
Time Before: 0.05090 seconds
Time After: 0.05116 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.049557209014893 seconds with 9 queries, spending 0.011169195175171 doing MySQL queries and 0.038388013839722 doing PHP things.
