Time Before: 0.02394 seconds
Time After: 0.03097 seconds
Time Taken: 0.00703 seconds
Time Before: 0.03108 seconds
Time After: 0.03160 seconds
Time Before: 0.03188 seconds
Time After: 0.03202 seconds
Time Before: 0.03292 seconds
Time After: 0.03548 seconds
Time Taken: 0.00256 seconds
Time Before: 0.03210 seconds
Time After: 0.03983 seconds
Time Taken: 0.00773 seconds
Time Before: 0.04676 seconds
Time After: 0.04718 seconds
Time Before: 0.05044 seconds
Time After: 0.05161 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04581 seconds
Time After: 0.05181 seconds
Time Taken: 0.00600 seconds
Time Before: 0.10262 seconds
Time After: 0.10285 seconds
Time Before: 0.12139 seconds
Time After: 0.12268 seconds
End call of global.php: 0.12499904632568
Time Before: 0.13276 seconds
Time After: 0.13293 seconds
Time Before: 0.13593 seconds
Time After: 0.13739 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123864', badlocation = 1
Time Before: 0.15636 seconds
Time After: 0.15679 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.15536618232727 seconds with 9 queries, spending 0.0084190368652344 doing MySQL queries and 0.14694714546204 doing PHP things.
