Time Before: 0.00217 seconds
Time After: 0.00301 seconds
Time Taken: 0.00084 seconds
Time Before: 0.00308 seconds
Time After: 0.00362 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00384 seconds
Time After: 0.00400 seconds
Time Before: 0.00467 seconds
Time After: 0.00748 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00405 seconds
Time After: 0.01091 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01351 seconds
Time After: 0.01372 seconds
Time Before: 0.01640 seconds
Time After: 0.01761 seconds
Time Before: 0.01278 seconds
Time After: 0.01784 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02373 seconds
Time After: 0.02394 seconds
Time Before: 0.02894 seconds
Time After: 0.03022 seconds
End call of global.php: 0.031940937042236
Time Before: 0.03331 seconds
Time After: 0.03348 seconds
Time Before: 0.03547 seconds
Time After: 0.03691 seconds
SET lastactivity = 1783282243, location = '/forums/private.php?do=newpm&explain=1&u=123866', badlocation = 1
Time Before: 0.04936 seconds
Time After: 0.04966 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.048476934432983 seconds with 9 queries, spending 0.0083229541778564 doing MySQL queries and 0.040153980255127 doing PHP things.
