Time Before: 0.01166 seconds
Time After: 0.01446 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01453 seconds
Time After: 0.01495 seconds
Time Before: 0.01517 seconds
Time After: 0.01531 seconds
Time Before: 0.01609 seconds
Time After: 0.01889 seconds
Time Before: 0.01538 seconds
Time After: 0.02315 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02880 seconds
Time After: 0.02921 seconds
Time Before: 0.03053 seconds
Time After: 0.03177 seconds
Time Before: 0.02811 seconds
Time After: 0.03196 seconds
Time Taken: 0.00385 seconds
Time Before: 0.04941 seconds
Time After: 0.04957 seconds
Time Before: 0.06000 seconds
Time After: 0.06130 seconds
End call of global.php: 0.063510179519653
Time Before: 0.06753 seconds
Time After: 0.06771 seconds
Time Before: 0.07028 seconds
Time After: 0.07175 seconds
SET lastactivity = 1776891516, location = '/forums/private.php?do=newpm&explain=1&u=123870', badlocation = 1
Time Before: 0.08906 seconds
Time After: 0.08969 seconds
Time Taken: 0.00063 seconds
Page generated in 0.088021993637085 seconds with 9 queries, spending 0.0087637901306152 doing MySQL queries and 0.07925820350647 doing PHP things.
