Time Before: 0.00925 seconds
Time After: 0.01395 seconds
Time Taken: 0.00469 seconds
Time Before: 0.01403 seconds
Time After: 0.01446 seconds
Time Before: 0.01473 seconds
Time After: 0.01485 seconds
Time Before: 0.01570 seconds
Time After: 0.01797 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01490 seconds
Time After: 0.02209 seconds
Time Taken: 0.00719 seconds
Time Before: 0.02938 seconds
Time After: 0.02982 seconds
Time Before: 0.03277 seconds
Time After: 0.03398 seconds
Time Before: 0.02869 seconds
Time After: 0.03422 seconds
Time Taken: 0.00553 seconds
Time Before: 0.06107 seconds
Time After: 0.06123 seconds
Time Before: 0.07292 seconds
Time After: 0.07416 seconds
End call of global.php: 0.076102018356323
Time Before: 0.08068 seconds
Time After: 0.08082 seconds
Time Before: 0.08310 seconds
Time After: 0.08459 seconds
SET lastactivity = 1773142634, location = '/forums/private.php?do=newpm&explain=1&u=123889'
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.09861 seconds
Time After: 0.09888 seconds
Page generated in 0.097664833068848 seconds with 9 queries, spending 0.0077681541442871 doing MySQL queries and 0.089896678924561 doing PHP things.
