Time Before: 0.00889 seconds
Time After: 0.01141 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01150 seconds
Time After: 0.01201 seconds
Time Before: 0.01224 seconds
Time After: 0.01242 seconds
Time Before: 0.01327 seconds
Time After: 0.01580 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01247 seconds
Time After: 0.01994 seconds
Time Taken: 0.00747 seconds
Time Before: 0.02405 seconds
Time After: 0.02444 seconds
Time Before: 0.02604 seconds
Time After: 0.02726 seconds
Time Before: 0.02337 seconds
Time After: 0.02749 seconds
Time Taken: 0.00412 seconds
Time Before: 0.04073 seconds
Time After: 0.04089 seconds
Time Before: 0.04543 seconds
Time After: 0.04670 seconds
End call of global.php: 0.049403190612793
Time Before: 0.05310 seconds
Time After: 0.05327 seconds
Time Before: 0.05535 seconds
Time After: 0.05681 seconds
SET lastactivity = 1783229991, location = '/forums/private.php?do=newpm&explain=1&u=123908', badlocation = 1
Time Before: 0.07032 seconds
Time After: 0.07189 seconds
Time Taken: 0.00158 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.069406032562256 seconds with 9 queries, spending 0.0094740390777588 doing MySQL queries and 0.059931993484497 doing PHP things.
