Time Before: 0.00184 seconds
Time After: 0.00260 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00274 seconds
Time After: 0.00313 seconds
Time Before: 0.00336 seconds
Time After: 0.00351 seconds
Time Before: 0.00441 seconds
Time After: 0.00749 seconds
Time Taken: 0.00308 seconds
Time Before: 0.00359 seconds
Time After: 0.01135 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01335 seconds
Time After: 0.01374 seconds
Time Before: 0.01637 seconds
Time After: 0.01767 seconds
Time Before: 0.01276 seconds
Time After: 0.01789 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02555 seconds
Time After: 0.02576 seconds
Time Before: 0.02825 seconds
Time After: 0.02953 seconds
End call of global.php: 0.032395839691162
Time Before: 0.03401 seconds
Time After: 0.03453 seconds
Time Before: 0.03790 seconds
Time After: 0.03937 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123921', badlocation = 1
Time Before: 0.05664 seconds
Time After: 0.05686 seconds
Page generated in 0.055330038070679 seconds with 9 queries, spending 0.0089976787567139 doing MySQL queries and 0.046332359313965 doing PHP things.
