Time Before: 0.00144 seconds
Time After: 0.00188 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00196 seconds
Time After: 0.00250 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00276 seconds
Time After: 0.00286 seconds
Time Taken: 0.00010 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00351 seconds
Time After: 0.00603 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00291 seconds
Time After: 0.00958 seconds
Time Taken: 0.00667 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01134 seconds
Time After: 0.01175 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01309 seconds
Time After: 0.01430 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01080 seconds
Time After: 0.01449 seconds
Time Taken: 0.00369 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02084 seconds
Time After: 0.02098 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02330 seconds
Time After: 0.02461 seconds
Time Taken: 0.00131 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.02745 seconds
Time After: 0.02758 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.02954 seconds
Time After: 0.03096 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123924' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04332 seconds
Time After: 0.04356 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
