Time Before: 0.00200 seconds
Time After: 0.00269 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00280 seconds
Time After: 0.00328 seconds
Time Before: 0.00353 seconds
Time After: 0.00368 seconds
Time Before: 0.00459 seconds
Time After: 0.00734 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00375 seconds
Time After: 0.01146 seconds
Time Taken: 0.00771 seconds
Time Before: 0.01326 seconds
Time After: 0.01343 seconds
Time Before: 0.01495 seconds
Time After: 0.01621 seconds
Time Before: 0.01266 seconds
Time After: 0.01638 seconds
Time Taken: 0.00372 seconds
Time Before: 0.02135 seconds
Time After: 0.02150 seconds
Time Before: 0.02463 seconds
Time After: 0.02588 seconds
Time Before: 0.03008 seconds
Time After: 0.03034 seconds
Time Before: 0.03263 seconds
Time After: 0.03414 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1784774338, location = '/forums/private.php?do=newpm&explain=1&u=123977', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04655 seconds
Time After: 0.04682 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
