Time Before: 0.02395 seconds
Time After: 0.03435 seconds
Time Taken: 0.01040 seconds
Time Before: 0.03446 seconds
Time After: 0.03493 seconds
Time Before: 0.03526 seconds
Time After: 0.03538 seconds
Time Before: 0.03619 seconds
Time After: 0.03858 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03544 seconds
Time After: 0.04275 seconds
Time Taken: 0.00730 seconds
Time Before: 0.05342 seconds
Time After: 0.05380 seconds
Time Before: 0.05632 seconds
Time After: 0.05765 seconds
Time Taken: 0.00133 seconds
Time Before: 0.05230 seconds
Time After: 0.05791 seconds
Time Taken: 0.00560 seconds
Time Before: 0.09337 seconds
Time After: 0.09351 seconds
Time Before: 0.13050 seconds
Time After: 0.13173 seconds
End call of global.php: 0.13379311561584
Time Before: 0.14449 seconds
Time After: 0.14466 seconds
Time Before: 0.14729 seconds
Time After: 0.14873 seconds
SET lastactivity = 1776460299, location = '/forums/private.php?do=newpm&explain=1&u=123996', badlocation = 1
Time Before: 0.16938 seconds
Time After: 0.17052 seconds
Time Taken: 0.00114 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.16842794418335 seconds with 9 queries, spending 0.0088248252868652 doing MySQL queries and 0.15960311889648 doing PHP things.
