Time Before: 0.00195 seconds
Time After: 0.00262 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00275 seconds
Time After: 0.00315 seconds
Time Before: 0.00339 seconds
Time After: 0.00352 seconds
Time Before: 0.00449 seconds
Time After: 0.00685 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00360 seconds
Time After: 0.01267 seconds
Time Taken: 0.00907 seconds
Time Before: 0.01450 seconds
Time After: 0.01490 seconds
Time Before: 0.01808 seconds
Time After: 0.01942 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01391 seconds
Time After: 0.01971 seconds
Time Taken: 0.00581 seconds
Time Before: 0.02738 seconds
Time After: 0.02755 seconds
Time Before: 0.02997 seconds
Time After: 0.03127 seconds
Time Before: 0.03576 seconds
Time After: 0.03599 seconds
Time Before: 0.03846 seconds
Time After: 0.03989 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124010' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05299 seconds
Time After: 0.05332 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
