Time Before: 0.01615 seconds
Time After: 0.01933 seconds
Time Taken: 0.00318 seconds
Time Before: 0.01944 seconds
Time After: 0.01989 seconds
Time Before: 0.02017 seconds
Time After: 0.02031 seconds
Time Before: 0.02132 seconds
Time After: 0.02390 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02037 seconds
Time After: 0.02803 seconds
Time Taken: 0.00766 seconds
Time Before: 0.03638 seconds
Time After: 0.03681 seconds
Time Before: 0.03990 seconds
Time After: 0.04108 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03565 seconds
Time After: 0.04126 seconds
Time Taken: 0.00561 seconds
Memory After: 2,885.109 KB
Memory Used: 132.781 KB
Time Before: 0.07722 seconds
Time After: 0.07736 seconds
Memory Before: 3,438.211 KB
Memory After: 3,438.727 KB
Time Before: 0.09046 seconds
Time After: 0.09169 seconds
Memory Before: 3,525.906 KB
Memory After: 3,526.500 KB
End call of global.php: 0.093728065490723
Time Before: 0.09983 seconds
Time After: 0.10000 seconds
Memory Before: 4,163.813 KB
Memory After: 4,164.242 KB
Time Before: 0.10276 seconds
Time After: 0.10420 seconds
Memory Before: 4,445.375 KB
Memory After: 4,447.063 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=124053'
Time Before: 0.12494 seconds
Time After: 0.12534 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.12358903884888 seconds with 9 queries, spending 0.0081503391265869 doing MySQL queries and 0.11543869972229 doing PHP things.
