Time Before: 0.00706 seconds
Time After: 0.00988 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00999 seconds
Time After: 0.01055 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01076 seconds
Time After: 0.01087 seconds
Time Before: 0.01193 seconds
Time After: 0.01438 seconds
Time Taken: 0.00245 seconds
Time Before: 0.01094 seconds
Time After: 0.01889 seconds
Time Taken: 0.00794 seconds
Time Before: 0.02312 seconds
Time After: 0.02354 seconds
Time Before: 0.02589 seconds
Time After: 0.02710 seconds
Time Before: 0.02231 seconds
Time After: 0.02733 seconds
Time Taken: 0.00502 seconds
Time Before: 0.04528 seconds
Time After: 0.04546 seconds
Time Before: 0.05286 seconds
Time After: 0.05414 seconds
End call of global.php: 0.056378841400146
Time Before: 0.06100 seconds
Time After: 0.06116 seconds
Time Before: 0.06408 seconds
Time After: 0.06560 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=124057'
Time Before: 0.08220 seconds
Time After: 0.08258 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.081036806106567 seconds with 9 queries, spending 0.0082740783691406 doing MySQL queries and 0.072762727737427 doing PHP things.
