Time Before: 0.01575 seconds
Time After: 0.02098 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02109 seconds
Time After: 0.02156 seconds
Time Before: 0.02182 seconds
Time After: 0.02194 seconds
Time Before: 0.02277 seconds
Time After: 0.02498 seconds
Time Taken: 0.00221 seconds
Time Before: 0.02200 seconds
Time After: 0.02963 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03691 seconds
Time After: 0.03733 seconds
Time Before: 0.03879 seconds
Time After: 0.04002 seconds
Time Before: 0.03615 seconds
Time After: 0.04028 seconds
Time Taken: 0.00413 seconds
Time Before: 0.06575 seconds
Time After: 0.06588 seconds
Time Before: 0.07662 seconds
Time After: 0.07786 seconds
Time Before: 0.08584 seconds
Time After: 0.08601 seconds
Time Before: 0.08835 seconds
Time After: 0.08985 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1776891669, location = '/forums/private.php?do=newpm&explain=1&u=124058' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.10732 seconds
Time After: 0.10764 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
