Time Before: 0.01432 seconds
Time After: 0.01950 seconds
Time Taken: 0.00517 seconds
Time Before: 0.01960 seconds
Time After: 0.02014 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02036 seconds
Time After: 0.02050 seconds
Time Before: 0.02129 seconds
Time After: 0.02347 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02055 seconds
Time After: 0.02761 seconds
Time Taken: 0.00706 seconds
Time Before: 0.03316 seconds
Time After: 0.03357 seconds
Time Before: 0.03608 seconds
Time After: 0.03736 seconds
Time Before: 0.03248 seconds
Time After: 0.03759 seconds
Time Taken: 0.00512 seconds
Time Before: 0.05941 seconds
Time After: 0.05957 seconds
Time Before: 0.07361 seconds
Time After: 0.07490 seconds
End call of global.php: 0.077452182769775
Time Before: 0.08199 seconds
Time After: 0.08227 seconds
Time Before: 0.08479 seconds
Time After: 0.08635 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=124064', badlocation = 1
Time Before: 0.10847 seconds
Time After: 0.10875 seconds
Page generated in 0.1070921421051 seconds with 9 queries, spending 0.008129358291626 doing MySQL queries and 0.098962783813477 doing PHP things.
