Time Before: 0.00814 seconds
Time After: 0.01026 seconds
Time Taken: 0.00213 seconds
Time Before: 0.01033 seconds
Time After: 0.01069 seconds
Time Before: 0.01090 seconds
Time After: 0.01104 seconds
Time Before: 0.01170 seconds
Time After: 0.01395 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01109 seconds
Time After: 0.01848 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02280 seconds
Time After: 0.02322 seconds
Time Before: 0.02580 seconds
Time After: 0.02698 seconds
Time Before: 0.02205 seconds
Time After: 0.02719 seconds
Time Taken: 0.00514 seconds
Time Before: 0.04632 seconds
Time After: 0.04645 seconds
Time Before: 0.05342 seconds
Time After: 0.05468 seconds
End call of global.php: 0.056859016418457
Time Before: 0.06115 seconds
Time After: 0.06134 seconds
Time Before: 0.06388 seconds
Time After: 0.06535 seconds
SET lastactivity = 1783379741, location = '/forums/private.php?do=newpm&explain=1&u=124068', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.08333 seconds
Time After: 0.08366 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.082123994827271 seconds with 9 queries, spending 0.0077435970306396 doing MySQL queries and 0.074380397796631 doing PHP things.
