Time Before: 0.01014 seconds
Time After: 0.01408 seconds
Time Taken: 0.00394 seconds
Time Before: 0.01414 seconds
Time After: 0.01453 seconds
Time Before: 0.01471 seconds
Time After: 0.01484 seconds
Time Before: 0.01553 seconds
Time After: 0.01770 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01490 seconds
Time After: 0.02139 seconds
Time Taken: 0.00648 seconds
Time Before: 0.02736 seconds
Time After: 0.02774 seconds
Time Before: 0.03037 seconds
Time After: 0.03159 seconds
Time Before: 0.02673 seconds
Time After: 0.03187 seconds
Time Taken: 0.00515 seconds
Time Before: 0.05452 seconds
Time After: 0.05468 seconds
Time Before: 0.06658 seconds
Time After: 0.06788 seconds
Time Before: 0.07907 seconds
Time After: 0.07924 seconds
Time Before: 0.08180 seconds
Time After: 0.08327 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124105' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.10116 seconds
Time After: 0.10155 seconds
