Time Before: 0.02436 seconds
Time After: 0.03167 seconds
Time Taken: 0.00730 seconds
Time Before: 0.03179 seconds
Time After: 0.03225 seconds
Time Before: 0.03252 seconds
Time After: 0.03269 seconds
Time Before: 0.03339 seconds
Time After: 0.03531 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03275 seconds
Time After: 0.03965 seconds
Time Taken: 0.00690 seconds
Time Before: 0.04841 seconds
Time After: 0.04881 seconds
Time Before: 0.05160 seconds
Time After: 0.05394 seconds
Time Taken: 0.00234 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04766 seconds
Time After: 0.05418 seconds
Time Taken: 0.00652 seconds
Memory After: 2,261.703 KB
Time Before: 0.11167 seconds
Time After: 0.11185 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.13794 seconds
Time After: 0.13920 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.14917 seconds
Time After: 0.14934 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.15187 seconds
Time After: 0.15330 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124142' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.17426 seconds
Time After: 0.17450 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
