Time Before: 0.00149 seconds
Time After: 0.00196 seconds
Time Before: 0.00203 seconds
Time After: 0.00259 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00281 seconds
Time After: 0.00294 seconds
Time Before: 0.00369 seconds
Time After: 0.00663 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00299 seconds
Time After: 0.00996 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01181 seconds
Time After: 0.01220 seconds
Time Before: 0.01492 seconds
Time After: 0.01622 seconds
Time Before: 0.01119 seconds
Time After: 0.01639 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02152 seconds
Time After: 0.02172 seconds
Time Before: 0.02442 seconds
Time After: 0.02613 seconds
Time Taken: 0.00171 seconds
End call of global.php: 0.027755975723267
Time Before: 0.02910 seconds
Time After: 0.02934 seconds
Time Before: 0.03143 seconds
Time After: 0.03285 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=124144', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04539 seconds
Time After: 0.04564 seconds
Page generated in 0.044504165649414 seconds with 9 queries, spending 0.0091462135314941 doing MySQL queries and 0.03535795211792 doing PHP things.
