Time Before: 0.00132 seconds
Time After: 0.00174 seconds
Time Before: 0.00181 seconds
Time After: 0.00239 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00261 seconds
Time After: 0.00271 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00333 seconds
Time After: 0.00573 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00276 seconds
Time After: 0.00907 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01105 seconds
Time After: 0.01139 seconds
Time Before: 0.01391 seconds
Time After: 0.01572 seconds
Time Taken: 0.00181 seconds
Time Before: 0.01043 seconds
Time After: 0.01589 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02352 seconds
Time After: 0.02369 seconds
Time Before: 0.02574 seconds
Time After: 0.02694 seconds
Time Before: 0.03035 seconds
Time After: 0.03075 seconds
Time Before: 0.03274 seconds
Time After: 0.03414 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1788902642, location = '/forums/private.php?do=newpm&explain=1&u=124161', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04637 seconds
Time After: 0.04676 seconds
