Time Before: 0.00152 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00249 seconds
Time Before: 0.00273 seconds
Time After: 0.00288 seconds
Time Before: 0.00371 seconds
Time After: 0.00779 seconds
Time Taken: 0.00408 seconds
Time Before: 0.00296 seconds
Time After: 0.01275 seconds
Time Taken: 0.00979 seconds
Time Before: 0.01485 seconds
Time After: 0.01531 seconds
Time Before: 0.01772 seconds
Time After: 0.01893 seconds
Time Before: 0.01412 seconds
Time After: 0.01909 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02417 seconds
Time After: 0.02432 seconds
Time Before: 0.02631 seconds
Time After: 0.02759 seconds
Time Before: 0.03046 seconds
Time After: 0.03063 seconds
Time Before: 0.03253 seconds
Time After: 0.03398 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124183' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04641 seconds
Time After: 0.04672 seconds
