Time Before: 0.01426 seconds
Time After: 0.01757 seconds
Time Taken: 0.00331 seconds
Time Before: 0.01766 seconds
Time After: 0.01800 seconds
Time Before: 0.01822 seconds
Time After: 0.01835 seconds
Time Before: 0.01913 seconds
Time After: 0.02153 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01842 seconds
Time After: 0.02525 seconds
Time Taken: 0.00684 seconds
Time Before: 0.02955 seconds
Time After: 0.02993 seconds
Time Before: 0.03275 seconds
Time After: 0.03389 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02879 seconds
Time After: 0.03407 seconds
Time Taken: 0.00528 seconds
Memory After: 2,261.703 KB
Time Before: 0.05008 seconds
Time After: 0.05021 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06144 seconds
Time After: 0.06268 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.064958095550537
Time Before: 0.06867 seconds
Time After: 0.06883 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07169 seconds
Time After: 0.07373 seconds
Time Taken: 0.00204 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=124231', badlocation = 1
Time Before: 0.09031 seconds
Time After: 0.09057 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.08932089805603 seconds with 9 queries, spending 0.0082216262817383 doing MySQL queries and 0.081099271774292 doing PHP things.
