Time Before: 0.01504 seconds
Time After: 0.02443 seconds
Time Taken: 0.00939 seconds
Time Before: 0.02454 seconds
Time After: 0.02503 seconds
Time Before: 0.02528 seconds
Time After: 0.02541 seconds
Time Before: 0.02650 seconds
Time After: 0.02898 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02548 seconds
Time After: 0.03386 seconds
Time Taken: 0.00838 seconds
Time Before: 0.04263 seconds
Time After: 0.04311 seconds
Time Before: 0.04651 seconds
Time After: 0.04770 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04191 seconds
Time After: 0.04793 seconds
Time Taken: 0.00602 seconds
Memory After: 2,261.703 KB
Time Before: 0.07071 seconds
Time After: 0.07089 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.46547 seconds
Time After: 0.46691 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.47842 seconds
Time After: 0.47862 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.48115 seconds
Time After: 0.48259 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124311', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.50092 seconds
Time After: 0.50131 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
