Time Before: 0.02490 seconds
Time After: 0.03467 seconds
Time Taken: 0.00976 seconds
Time Before: 0.03479 seconds
Time After: 0.03524 seconds
Time Before: 0.03551 seconds
Time After: 0.03565 seconds
Time Before: 0.03635 seconds
Time After: 0.03903 seconds
Time Taken: 0.00268 seconds
Time Before: 0.03572 seconds
Time After: 0.04319 seconds
Time Taken: 0.00748 seconds
Time Before: 0.05285 seconds
Time After: 0.05352 seconds
Time Taken: 0.00067 seconds
Time Before: 0.05484 seconds
Time After: 0.05604 seconds
Time Before: 0.05222 seconds
Time After: 0.05624 seconds
Time Taken: 0.00402 seconds
Time Before: 0.08942 seconds
Time After: 0.08959 seconds
Time Before: 0.10915 seconds
Time After: 0.11049 seconds
Time Taken: 0.00135 seconds
Time Before: 0.12638 seconds
Time After: 0.12656 seconds
Time Before: 0.12897 seconds
Time After: 0.13042 seconds
UPDATE session SET lastactivity = 1784797578, location = '/forums/private.php?do=newpm&explain=1&u=124322' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.14964 seconds
Time After: 0.14991 seconds
