Time Before: 0.02551 seconds
Time After: 0.03599 seconds
Time Taken: 0.01048 seconds
Time Before: 0.03611 seconds
Time After: 0.03653 seconds
Time Before: 0.03681 seconds
Time After: 0.03697 seconds
Time Before: 0.03789 seconds
Time After: 0.04079 seconds
Time Taken: 0.00290 seconds
Time Before: 0.03706 seconds
Time After: 0.04566 seconds
Time Taken: 0.00860 seconds
Time Before: 0.05603 seconds
Time After: 0.05641 seconds
Time Before: 0.05866 seconds
Time After: 0.05984 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05522 seconds
Time After: 0.06003 seconds
Time Taken: 0.00481 seconds
Time Before: 0.10848 seconds
Time After: 0.10868 seconds
Time Before: 0.12288 seconds
Time After: 0.12409 seconds
Time Before: 0.13397 seconds
Time After: 0.13417 seconds
Time Before: 0.13679 seconds
Time After: 0.13825 seconds
UPDATE session SET lastactivity = 1772799308, location = '/forums/private.php?do=newpm&explain=1&u=124345', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.15801 seconds
Time After: 0.15828 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
