Time Before: 0.00202 seconds
Time After: 0.00264 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00274 seconds
Time After: 0.00327 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00351 seconds
Time After: 0.00449 seconds
Time Taken: 0.00098 seconds
Time Before: 0.00538 seconds
Time After: 0.00833 seconds
Time Taken: 0.00296 seconds
Time Before: 0.00455 seconds
Time After: 0.01376 seconds
Time Taken: 0.00921 seconds
Time Before: 0.01598 seconds
Time After: 0.01638 seconds
Time Before: 0.01891 seconds
Time After: 0.02022 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01537 seconds
Time After: 0.02046 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.820 KB
Time Before: 0.02696 seconds
Time After: 0.02711 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02964 seconds
Time After: 0.03089 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.033612012863159
Time Before: 0.03677 seconds
Time After: 0.03691 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03968 seconds
Time After: 0.04116 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788902008, location = '/forums/private.php?do=newpm&explain=1&u=124366'
Time Before: 0.06079 seconds
Time After: 0.06118 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.059385061264038 seconds with 9 queries, spending 0.0095920562744141 doing MySQL queries and 0.049793004989624 doing PHP things.
