Time Before: 0.01992 seconds
Time After: 0.02494 seconds
Time Taken: 0.00502 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02506 seconds
Time After: 0.02559 seconds
Time Taken: 0.00053 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02583 seconds
Time After: 0.02594 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02674 seconds
Time After: 0.02914 seconds
Time Taken: 0.00240 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02600 seconds
Time After: 0.03323 seconds
Time Taken: 0.00723 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.03950 seconds
Time After: 0.03990 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.04266 seconds
Time After: 0.04383 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.03874 seconds
Time After: 0.04404 seconds
Time Taken: 0.00530 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.08360 seconds
Time After: 0.08380 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10014 seconds
Time After: 0.10165 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
Time Before: 0.11263 seconds
Time After: 0.11280 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.11506 seconds
Time After: 0.11656 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
UPDATE session SET lastactivity = 1782846835, location = '/forums/private.php?do=newpm&explain=1&u=124422' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.13248 seconds
Time After: 0.13278 seconds
Memory Before: 4,296.648 KB
Memory After: 4,296.875 KB
