Time Before: 0.00151 seconds
Time After: 0.00202 seconds
Time Before: 0.00209 seconds
Time After: 0.00251 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00385 seconds
Time After: 0.00678 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00300 seconds
Time After: 0.01162 seconds
Time Taken: 0.00862 seconds
Time Before: 0.01366 seconds
Time After: 0.01411 seconds
Time Before: 0.01564 seconds
Time After: 0.01682 seconds
Time Before: 0.01286 seconds
Time After: 0.01708 seconds
Time Taken: 0.00422 seconds
Time Before: 0.02408 seconds
Time After: 0.02449 seconds
Time Before: 0.02689 seconds
Time After: 0.02810 seconds
End call of global.php: 0.030659198760986
Time Before: 0.03213 seconds
Time After: 0.03232 seconds
Time Before: 0.03569 seconds
Time After: 0.03784 seconds
Time Taken: 0.00215 seconds
SET lastactivity = 1789016316, location = '/forums/private.php?do=newpm&explain=1&u=124450', badlocation = 1
Time Before: 0.05072 seconds
Time After: 0.05114 seconds
Page generated in 0.049772977828979 seconds with 9 queries, spending 0.0095186233520508 doing MySQL queries and 0.040254354476929 doing PHP things.
