Time Before: 0.00957 seconds
Time After: 0.01367 seconds
Time Taken: 0.00410 seconds
Time Before: 0.01374 seconds
Time After: 0.01423 seconds
Time Before: 0.01456 seconds
Time After: 0.01473 seconds
Time Before: 0.01550 seconds
Time After: 0.01821 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01481 seconds
Time After: 0.02401 seconds
Time Taken: 0.00920 seconds
Time Before: 0.02895 seconds
Time After: 0.02937 seconds
Time Before: 0.03090 seconds
Time After: 0.03210 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02832 seconds
Time After: 0.03235 seconds
Time Taken: 0.00403 seconds
Memory After: 2,261.703 KB
Time Before: 0.04851 seconds
Time After: 0.04866 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05968 seconds
Time After: 0.06094 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.06770 seconds
Time After: 0.06788 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07041 seconds
Time After: 0.07187 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124456' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08907 seconds
Time After: 0.08949 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
