Time Before: 0.01270 seconds
Time After: 0.02004 seconds
Time Taken: 0.00734 seconds
Time Before: 0.02014 seconds
Time After: 0.02069 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02095 seconds
Time After: 0.02113 seconds
Time Before: 0.02192 seconds
Time After: 0.02423 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02118 seconds
Time After: 0.02902 seconds
Time Taken: 0.00784 seconds
Time Before: 0.03859 seconds
Time After: 0.03900 seconds
Time Before: 0.04170 seconds
Time After: 0.04301 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03786 seconds
Time After: 0.04325 seconds
Time Taken: 0.00538 seconds
Memory After: 2,261.703 KB
Time Before: 0.06340 seconds
Time After: 0.06390 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08554 seconds
Time After: 0.08684 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09972 seconds
Time After: 0.09992 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10265 seconds
Time After: 0.10496 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124484' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12500 seconds
Time After: 0.12528 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
