Time Before: 0.00256 seconds
Time After: 0.00306 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00313 seconds
Time After: 0.00352 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00370 seconds
Time After: 0.00382 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00448 seconds
Time After: 0.00653 seconds
Time Taken: 0.00206 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00387 seconds
Time After: 0.00994 seconds
Time Taken: 0.00608 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01185 seconds
Time After: 0.01221 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01494 seconds
Time After: 0.01642 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01122 seconds
Time After: 0.01664 seconds
Time Taken: 0.00541 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02318 seconds
Time After: 0.02335 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03230 seconds
Time After: 0.03357 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04285 seconds
Time After: 0.04304 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04519 seconds
Time After: 0.04663 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124642' WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.06099 seconds
Time After: 0.06125 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
