Time Before: 0.00845 seconds
Time After: 0.01216 seconds
Time Taken: 0.00371 seconds
Time Before: 0.01226 seconds
Time After: 0.01284 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01312 seconds
Time After: 0.01324 seconds
Time Before: 0.01415 seconds
Time After: 0.01665 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01331 seconds
Time After: 0.02100 seconds
Time Taken: 0.00768 seconds
Time Before: 0.02569 seconds
Time After: 0.02601 seconds
Time Before: 0.02850 seconds
Time After: 0.02978 seconds
Time Before: 0.02505 seconds
Time After: 0.03004 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05024 seconds
Time After: 0.05042 seconds
Time Before: 0.05880 seconds
Time After: 0.06007 seconds
Time Before: 0.06571 seconds
Time After: 0.06590 seconds
Time Before: 0.06875 seconds
Time After: 0.07028 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1776567518, location = '/forums/private.php?do=newpm&explain=1&u=124647' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.09046 seconds
Time After: 0.09084 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
