Time Before: 0.00388 seconds
Time After: 0.00530 seconds
Time Before: 0.00540 seconds
Time After: 0.00587 seconds
Time Before: 0.00610 seconds
Time After: 0.00623 seconds
Time Before: 0.00713 seconds
Time After: 0.00934 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00631 seconds
Time After: 0.01518 seconds
Time Taken: 0.00886 seconds
Time Before: 0.01940 seconds
Time After: 0.01981 seconds
Time Before: 0.02245 seconds
Time After: 0.02369 seconds
Time Before: 0.01863 seconds
Time After: 0.02395 seconds
Time Taken: 0.00532 seconds
Time Before: 0.03147 seconds
Time After: 0.03161 seconds
Time Before: 0.03720 seconds
Time After: 0.03845 seconds
End call of global.php: 0.041038990020752
Time Before: 0.04416 seconds
Time After: 0.04432 seconds
Time Before: 0.04757 seconds
Time After: 0.04906 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=124658'
Time Before: 0.06707 seconds
Time After: 0.06749 seconds
Page generated in 0.065708875656128 seconds with 9 queries, spending 0.0079348087310791 doing MySQL queries and 0.057774066925049 doing PHP things.
