Time Before: 0.01312 seconds
Time After: 0.01865 seconds
Time Taken: 0.00553 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01878 seconds
Time After: 0.01922 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01944 seconds
Time After: 0.01956 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02046 seconds
Time After: 0.02251 seconds
Time Taken: 0.00205 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01964 seconds
Time After: 0.02769 seconds
Time Taken: 0.00805 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03220 seconds
Time After: 0.03262 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03579 seconds
Time After: 0.03760 seconds
Time Taken: 0.00181 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03141 seconds
Time After: 0.03779 seconds
Time Taken: 0.00638 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.06643 seconds
Time After: 0.06659 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.09834 seconds
Time After: 0.10009 seconds
Time Taken: 0.00175 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.11743 seconds
Time After: 0.11758 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.12142 seconds
Time After: 0.12285 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124671' WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.14957 seconds
Time After: 0.15000 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
