Time Before: 0.00156 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00260 seconds
Time Before: 0.00283 seconds
Time After: 0.00296 seconds
Time Before: 0.00360 seconds
Time After: 0.00637 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00301 seconds
Time After: 0.00979 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01150 seconds
Time After: 0.01190 seconds
Time Before: 0.01460 seconds
Time After: 0.01586 seconds
Time Before: 0.01087 seconds
Time After: 0.01610 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02238 seconds
Time After: 0.02258 seconds
Time Before: 0.02446 seconds
Time After: 0.02571 seconds
Time Before: 0.02898 seconds
Time After: 0.02919 seconds
Time Before: 0.03218 seconds
Time After: 0.03366 seconds
UPDATE session SET lastactivity = 1789142865, location = '/forums/private.php?do=newpm&explain=1&u=124695', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04630 seconds
Time After: 0.04670 seconds
