Time Before: 0.00289 seconds
Time After: 0.00367 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00375 seconds
Time After: 0.00447 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00477 seconds
Time After: 0.00515 seconds
Time Before: 0.00602 seconds
Time After: 0.00861 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00520 seconds
Time After: 0.01344 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01674 seconds
Time After: 0.01712 seconds
Time Before: 0.01951 seconds
Time After: 0.02172 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01602 seconds
Time After: 0.02189 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02728 seconds
Time After: 0.02756 seconds
Time Before: 0.03008 seconds
Time After: 0.03133 seconds
End call of global.php: 0.033836126327515
Time Before: 0.03531 seconds
Time After: 0.03553 seconds
Time Before: 0.03853 seconds
Time After: 0.04001 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=124719'
Time Before: 0.05672 seconds
Time After: 0.05697 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.055777072906494 seconds with 9 queries, spending 0.0097768306732178 doing MySQL queries and 0.046000242233276 doing PHP things.
