Time Before: 0.00751 seconds
Time After: 0.01034 seconds
Time Taken: 0.00283 seconds
Time Before: 0.01042 seconds
Time After: 0.01106 seconds
Time Taken: 0.00064 seconds
Time Before: 0.01130 seconds
Time After: 0.01145 seconds
Time Before: 0.01208 seconds
Time After: 0.01522 seconds
Time Taken: 0.00315 seconds
Time Before: 0.01150 seconds
Time After: 0.01858 seconds
Time Taken: 0.00708 seconds
Time Before: 0.02291 seconds
Time After: 0.02328 seconds
Time Before: 0.02602 seconds
Time After: 0.02953 seconds
Time Taken: 0.00351 seconds
Time Before: 0.02230 seconds
Time After: 0.02970 seconds
Time Taken: 0.00741 seconds
Time Before: 0.04363 seconds
Time After: 0.04375 seconds
Time Before: 0.05063 seconds
Time After: 0.05188 seconds
Time Before: 0.05719 seconds
Time After: 0.05785 seconds
Time Taken: 0.00066 seconds
Time Before: 0.06007 seconds
Time After: 0.06214 seconds
Time Taken: 0.00207 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124721', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.07807 seconds
Time After: 0.07839 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
