Time Before: 0.02076 seconds
Time After: 0.02835 seconds
Time Taken: 0.00759 seconds
Time Before: 0.02846 seconds
Time After: 0.02886 seconds
Time Before: 0.02911 seconds
Time After: 0.02923 seconds
Time Before: 0.02992 seconds
Time After: 0.03226 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02928 seconds
Time After: 0.03617 seconds
Time Taken: 0.00689 seconds
Time Before: 0.04805 seconds
Time After: 0.04839 seconds
Time Before: 0.05094 seconds
Time After: 0.05216 seconds
Time Before: 0.04731 seconds
Time After: 0.05240 seconds
Time Taken: 0.00509 seconds
Time Before: 0.08126 seconds
Time After: 0.08143 seconds
Time Before: 0.10425 seconds
Time After: 0.10547 seconds
Time Before: 0.11525 seconds
Time After: 0.11551 seconds
Time Before: 0.11841 seconds
Time After: 0.11985 seconds
UPDATE session SET lastactivity = 1776967176, location = '/forums/private.php?do=newpm&explain=1&u=124797', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.13839 seconds
Time After: 0.13862 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
