Time Before: 0.00204 seconds
Time After: 0.00266 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00274 seconds
Time After: 0.00334 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00366 seconds
Time After: 0.00381 seconds
Time Before: 0.00478 seconds
Time After: 0.00761 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00390 seconds
Time After: 0.01120 seconds
Time Taken: 0.00730 seconds
Time Before: 0.01333 seconds
Time After: 0.01376 seconds
Time Before: 0.01716 seconds
Time After: 0.01837 seconds
Time Before: 0.01272 seconds
Time After: 0.01866 seconds
Time Taken: 0.00594 seconds
Time Before: 0.02575 seconds
Time After: 0.02593 seconds
Time Before: 0.02784 seconds
Time After: 0.02905 seconds
Time Before: 0.03206 seconds
Time After: 0.03222 seconds
Time Before: 0.03450 seconds
Time After: 0.03598 seconds
UPDATE session SET lastactivity = 1783110398, location = '/forums/private.php?do=newpm&explain=1&u=124827' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04954 seconds
Time After: 0.04983 seconds
