Time Before: 0.00833 seconds
Time After: 0.01132 seconds
Time Taken: 0.00300 seconds
Time Before: 0.01143 seconds
Time After: 0.01195 seconds
Time Before: 0.01222 seconds
Time After: 0.01238 seconds
Time Before: 0.01328 seconds
Time After: 0.01628 seconds
Time Before: 0.01246 seconds
Time After: 0.02180 seconds
Time Taken: 0.00935 seconds
Time Before: 0.02825 seconds
Time After: 0.02870 seconds
Time Before: 0.03137 seconds
Time After: 0.03262 seconds
Time Before: 0.02758 seconds
Time After: 0.03288 seconds
Time Taken: 0.00530 seconds
Time Before: 0.04483 seconds
Time After: 0.04500 seconds
Time Before: 0.74550 seconds
Time After: 0.74717 seconds
Time Taken: 0.00167 seconds
Time Before: 0.75338 seconds
Time After: 0.75361 seconds
Time Before: 0.75612 seconds
Time After: 0.75762 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1784779306, location = '/forums/private.php?do=newpm&explain=1&u=124856', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.77784 seconds
Time After: 0.77813 seconds
