Time Before: 0.00899 seconds
Time After: 0.01167 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01176 seconds
Time After: 0.01220 seconds
Time Before: 0.01247 seconds
Time After: 0.01263 seconds
Time Before: 0.01350 seconds
Time After: 0.01590 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01273 seconds
Time After: 0.02036 seconds
Time Taken: 0.00762 seconds
Time Before: 0.02398 seconds
Time After: 0.02434 seconds
Time Before: 0.02700 seconds
Time After: 0.02826 seconds
Time Before: 0.02319 seconds
Time After: 0.02852 seconds
Time Taken: 0.00532 seconds
Time Before: 0.04521 seconds
Time After: 0.04537 seconds
Time Before: 0.05241 seconds
Time After: 0.05367 seconds
Time Before: 0.05813 seconds
Time After: 0.05834 seconds
Time Before: 0.06102 seconds
Time After: 0.06254 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=124921', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.08102 seconds
Time After: 0.08137 seconds
