Time Before: 0.00143 seconds
Time After: 0.00199 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00209 seconds
Time After: 0.00253 seconds
Time Before: 0.00279 seconds
Time After: 0.00296 seconds
Time Before: 0.00367 seconds
Time After: 0.00603 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00303 seconds
Time After: 0.00988 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01184 seconds
Time After: 0.01226 seconds
Time Before: 0.01477 seconds
Time After: 0.01593 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01124 seconds
Time After: 0.01611 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02107 seconds
Time After: 0.02128 seconds
Time Before: 0.02326 seconds
Time After: 0.02463 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.026956081390381
Time Before: 0.02834 seconds
Time After: 0.02853 seconds
Time Before: 0.03053 seconds
Time After: 0.03191 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1789145435, location = '/forums/private.php?do=newpm&explain=1&u=124960', badlocation = 1
Time Before: 0.04501 seconds
Time After: 0.04534 seconds
Page generated in 0.044091939926147 seconds with 9 queries, spending 0.0080349445343018 doing MySQL queries and 0.036056995391846 doing PHP things.
