Time Before: 0.00138 seconds
Time After: 0.00193 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00199 seconds
Time After: 0.00238 seconds
Time Before: 0.00266 seconds
Time After: 0.00277 seconds
Time Before: 0.00341 seconds
Time After: 0.00593 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00282 seconds
Time After: 0.00927 seconds
Time Taken: 0.00645 seconds
Time Before: 0.01160 seconds
Time After: 0.01198 seconds
Time Before: 0.01474 seconds
Time After: 0.01595 seconds
Time Before: 0.01102 seconds
Time After: 0.01611 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02113 seconds
Time After: 0.02127 seconds
Time Before: 0.02356 seconds
Time After: 0.02519 seconds
Time Taken: 0.00163 seconds
Time Before: 0.02923 seconds
Time After: 0.02937 seconds
Time Before: 0.03190 seconds
Time After: 0.03333 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=125045' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04939 seconds
Time After: 0.04989 seconds
