Time Before: 0.00393 seconds
Time After: 0.00592 seconds
Time Taken: 0.00199 seconds
Time Before: 0.00603 seconds
Time After: 0.00649 seconds
Time Before: 0.00672 seconds
Time After: 0.00692 seconds
Time Before: 0.00763 seconds
Time After: 0.01032 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00698 seconds
Time After: 0.01455 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01875 seconds
Time After: 0.01917 seconds
Time Before: 0.02075 seconds
Time After: 0.02199 seconds
Time Before: 0.01798 seconds
Time After: 0.02217 seconds
Time Taken: 0.00418 seconds
Time Before: 0.03050 seconds
Time After: 0.03063 seconds
Time Before: 0.03679 seconds
Time After: 0.03803 seconds
End call of global.php: 0.040195941925049
Time Before: 0.04444 seconds
Time After: 0.04478 seconds
Time Before: 0.04717 seconds
Time After: 0.04867 seconds
SET lastactivity = 1789016082, location = '/forums/private.php?do=newpm&explain=1&u=125052'
Time Before: 0.06166 seconds
Time After: 0.06195 seconds
Page generated in 0.060704946517944 seconds with 9 queries, spending 0.0085210800170898 doing MySQL queries and 0.052183866500854 doing PHP things.
