Time Before: 0.00154 seconds
Time After: 0.00213 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00220 seconds
Time After: 0.00270 seconds
Time Before: 0.00292 seconds
Time After: 0.00305 seconds
Time Before: 0.00370 seconds
Time After: 0.00639 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00310 seconds
Time After: 0.01001 seconds
Time Taken: 0.00691 seconds
Time Before: 0.01181 seconds
Time After: 0.01206 seconds
Time Before: 0.01487 seconds
Time After: 0.01605 seconds
Time Before: 0.01123 seconds
Time After: 0.01629 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02138 seconds
Time After: 0.02150 seconds
Time Before: 0.02349 seconds
Time After: 0.02474 seconds
End call of global.php: 0.026372194290161
Time Before: 0.02744 seconds
Time After: 0.02758 seconds
Time Before: 0.02954 seconds
Time After: 0.03092 seconds
Time Taken: 0.00138 seconds
SET lastactivity = 1783080929, location = '/forums/private.php?do=newpm&explain=1&u=125138', badlocation = 1
Time Before: 0.04331 seconds
Time After: 0.09274 seconds
Time Taken: 0.04944 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.042418003082275 seconds with 9 queries, spending 0.057098150253296 doing MySQL queries and -0.014680147171021 doing PHP things.
