Time Before: 0.00274 seconds
Time After: 0.00426 seconds
Time Taken: 0.00153 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00436 seconds
Time After: 0.00550 seconds
Time Taken: 0.00114 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00575 seconds
Time After: 0.00586 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00669 seconds
Time After: 0.00949 seconds
Time Taken: 0.00280 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00592 seconds
Time After: 0.01445 seconds
Time Taken: 0.00853 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01686 seconds
Time After: 0.01713 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01962 seconds
Time After: 0.02077 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01619 seconds
Time After: 0.02095 seconds
Time Taken: 0.00477 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02753 seconds
Time After: 0.02771 seconds
Memory Before: 3,655.742 KB
Memory After: 3,656.258 KB
Time Before: 0.03549 seconds
Time After: 0.03673 seconds
Memory Before: 4,133.320 KB
Memory After: 4,133.914 KB
End call of global.php: 0.038484811782837
Time Before: 0.04488 seconds
Time After: 0.04506 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.04739 seconds
Time After: 0.04886 seconds
Memory Before: 5,481.211 KB
Memory After: 5,610.813 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=125149', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.06389 seconds
Time After: 0.06425 seconds
Memory Before: 5,998.508 KB
Memory After: 5,998.727 KB
Page generated in 0.062927961349487 seconds with 9 queries, spending 0.0088901519775391 doing MySQL queries and 0.054037809371948 doing PHP things.
