Time Before: 0.00140 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00202 seconds
Time After: 0.00242 seconds
Time Before: 0.00265 seconds
Time After: 0.00276 seconds
Time Before: 0.00359 seconds
Time After: 0.00656 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00281 seconds
Time After: 0.01129 seconds
Time Taken: 0.00848 seconds
Time Before: 0.01336 seconds
Time After: 0.01376 seconds
Time Before: 0.01714 seconds
Time After: 0.01844 seconds
Time Before: 0.01274 seconds
Time After: 0.01870 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02524 seconds
Time After: 0.02541 seconds
Time Before: 0.02771 seconds
Time After: 0.02891 seconds
End call of global.php: 0.030591011047363
Time Before: 0.03195 seconds
Time After: 0.03218 seconds
Time Before: 0.03432 seconds
Time After: 0.03606 seconds
Time Taken: 0.00174 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=12515', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04888 seconds
Time After: 0.04915 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.047866106033325 seconds with 9 queries, spending 0.0088136196136475 doing MySQL queries and 0.039052486419678 doing PHP things.
