Time Before: 0.00849 seconds
Time After: 0.01146 seconds
Time Taken: 0.00297 seconds
Time Before: 0.01157 seconds
Time After: 0.01202 seconds
Time Before: 0.01227 seconds
Time After: 0.01242 seconds
Time Before: 0.01320 seconds
Time After: 0.01549 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01249 seconds
Time After: 0.02029 seconds
Time Taken: 0.00781 seconds
Time Before: 0.02487 seconds
Time After: 0.02552 seconds
Time Taken: 0.00064 seconds
Time Before: 0.02830 seconds
Time After: 0.02962 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02415 seconds
Time After: 0.02981 seconds
Time Taken: 0.00566 seconds
Time Before: 0.04683 seconds
Time After: 0.04698 seconds
Time Before: 0.05468 seconds
Time After: 0.05597 seconds
End call of global.php: 0.058140993118286
Time Before: 0.06322 seconds
Time After: 0.06339 seconds
Time Before: 0.06561 seconds
Time After: 0.06706 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=125192', badlocation = 1
Time Before: 0.08365 seconds
Time After: 0.08398 seconds
Page generated in 0.082628965377808 seconds with 9 queries, spending 0.0082402229309082 doing MySQL queries and 0.074388742446899 doing PHP things.
