Time Before: 0.00205 seconds
Time After: 0.00277 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00288 seconds
Time After: 0.00354 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00379 seconds
Time After: 0.00392 seconds
Time Before: 0.00477 seconds
Time After: 0.00744 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00400 seconds
Time After: 0.01230 seconds
Time Taken: 0.00830 seconds
Time Before: 0.01459 seconds
Time After: 0.01500 seconds
Time Before: 0.01792 seconds
Time After: 0.01913 seconds
Time Before: 0.01381 seconds
Time After: 0.01930 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02421 seconds
Time After: 0.02434 seconds
Time Before: 0.02619 seconds
Time After: 0.02741 seconds
End call of global.php: 0.029064893722534
Time Before: 0.03040 seconds
Time After: 0.03055 seconds
Time Before: 0.03263 seconds
Time After: 0.03411 seconds
SET lastactivity = 1772880733, location = '/forums/private.php?do=newpm&explain=1&u=125207'
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04640 seconds
Time After: 0.04672 seconds
Page generated in 0.045496940612793 seconds with 9 queries, spending 0.0083677768707275 doing MySQL queries and 0.037129163742065 doing PHP things.
